Moviment Graffitti logo
Latest News
An informed discussion on the Malta-Gozo tunnel has yet to start
Whilst fully acknowledging the need to address mobility challenges experienced by Gozitan workers and students, we express our disagreement with declarations that the discussion about the Malta-Gozo tunnel is closed and that we are now at an ‘implementation stage’. The discussion has not even begun as there is currently a total lack of studies and information on the utility and impacts of the tunnel. Indeed, it has not even been established whether a tunnel will actually facilitate mobility between the two islands. A decision on whether a tunnel is the best solution to mobility challenges should only be taken after independent, serious and holistic studies have been conducted. Moreover, the public has a right to participate in meaningful consultation, and to be provided with information on this subject to develop an informed opinion.
The impression given by the Project Description Statement published by the Environment and Resources Authority (ERA) is that the tunnel will provide a seamless connection between Malta and Gozo. However, in practice, this won’t necessarily be the case. What is being proposed is a relatively narrow tunnel with one lane in each direction. Considering that up to 9,000 cars will pass through the tunnel daily, coupled with the fact that the tunnel itself might have capacity limitations due to safety issues, the possibility of queuing remains. Studies should determine whether the tunnel will indeed reduce the average journey times between Malta and Gozo, taking into account the capacity of the tunnel itself, as well as higher congestion along the routes leading to it.
The tunnel option should also be compared with other options in terms of costs, impacts and efficacy. For example, a fast-ferry service providing frequent trips from Gozo to different parts of the Maltese island has to be seriously considered. One should bear in mind that a tunnel will inevitably lead to the northern part of the Maltese island, with Gozitans having to then travel all the way to their place of work or study, possibly encountering increased traffic jams along the way. A fast-ferry service might address this in ways that the tunnel cannot. The best solution for improving the connectivity between the two islands can only be determined through studies that consider and compare all possible options.
The tunnel option should also be assessed from a financial sustainability perspective. While the exact costs of the tunnel have not yet been determined, it is estimated that construction costs can hit the 300 million mark. Additionally, a tunnel requires millions of euros annually to monitor, maintain and operate. Assertions that the tunnel will be privately funded in its entirety are unrealistic. If the toll is to remain affordable, constant and significant Government subsidies will be inevitable. Studies should determine the extent of these subsidies and their long-term sustainability.
It is essential that studies about the tunnel are not limited to the construction and operation of the tunnel itself, but taken with a broad view of its impacts. For instance, studies should establish the ripple effect of the tunnel on Gozitan society and its economy, environment and infrastructure, as a result of the rise in cars and in speculative development pressures.
The tunnel is expected to impact the environment on many levels. Prior to deciding on the tunnel option, the full extent of its environmental impacts on Malta and Gozo should be assessed, taking into account factors such as:
  • the take-up of arable and natural land for the two entrances and for ancillary road networks, which is bound to be high
  • the generation of an unprecedented volume of waste, estimated to be in excess of one million cubic meters
  • the direct and indirect effects on at least four Natura 2000 sites, two of which include the Nature Reserves of Simar and Ghadira
  • the potential devastating effects on the Miżieb/l-Imbordin uncontaminated perched aquifer, which has provided water for the Pwales valley for millennia
  • the possible destruction and/or contamination of the Pwales aquifer, which at present yields about six million cubic metres of water per annum
  • the increase in traffic and pollution, and its impact on the natural environment and the quality of life, in both Malta and Gozo
  • noise and vibrations resulting from excavation works and their impact on the seabed and on the surrounding habitats
  • the availability of cycling infrastructure which, if lacking, would force commuters to travel by car instead.
The current proposal, which places the Malta tunnel portal close to the quaint hamlet of l-Imbordin, also raises a number of serious archaeological concerns. The l-Imbordin area contains natural and partly enlarged cave dwellings, probably dating to a pre-Knights period, and is also known for its Knights’ period ‘giardini’. Both the cave dwellings and the ‘giardini’ will likely be threatened by the excavation of the tunnel entrance and its infrastructure. The dwellings have been used for centuries and are in good condition. Moreover, the identification of archaeological remains in the area is ongoing.
Considering the undeniable large-scale impact of the tunnel, we call for a Strategic Environment Assessment (SEA), to be carried out before proceeding with any further plans. The SEA is a legal obligation for any plan or programme prepared by government which is likely to have a significant effect on the environment. This has the aim of predicting environmental impacts, evaluating reasonable alternatives and mitigation measures, engaging in broad consultation and influencing the plans by addressing environmental issues at an early stage.
It is only after the necessary studies are concluded and published that a meaningful discussion on the Malta-Gozo tunnel can begin. These studies should provide answers to several important questions, including:
  • Taking into account capacity limitations and the increase in traffic, will the tunnel actually reduce the journey times between the two islands?
  • How does the tunnel option compare to other possible options, such as a fast-ferry service, in terms of efficacy, costs and impacts?
  • Are the short-term and long-term costs of the tunnel financially sustainable?
  • How will the tunnel effect Gozitan society, economy, environment and infrastructure?
  • What is the full extent of the tunnel’s impact on the environment?
At this stage, we have nothing that shows that the tunnel will effectively address mobility challenges, and that its social, economic and environmental impacts will be sustainable.
We look forward to actively participating in an informed discussion on this subject.
The 13 organisations participating in the Press Conference are:
Ramblers Association, Din l-Art Ħelwa, Archaeological Society Malta, Moviment Graffitti, BirdLife Malta, Kamra tal-Periti, Nature Trust Malta, Flimkien għal Ambjent Aħjar, Friends of the Earth Malta, Għaqda Siġar Maltin, Isles of the Left, Bicycle Advocacy Group and Żminijietna
______________________________________________________________________
Għad trid issir diskussjoni infurmata dwar il-mina bejn Malta u Għawdex
Filwaqt li nirrikonoxxu bis-sħiħ il-ħtieġa li jiġu indirizzati l-isfidi ta’ mobilità li qed jiffaċċjaw il-ħaddiema u l-istudenti Għawdxin, nixtiequ nesprimu n-nuqqas ta’ qbil tagħna mad-dikjarazzjonijiet li saru fejn intqal li d-diskussjonijiet dwar il-mina bejn Malta u Għawdex huma magħluqin u li issa ninsabu “f’fażi ta’ implimentazzjoni.” Id-diskussjoni għadha lanqas biss bdiet, peress li bħalissa hemm nuqqas totali ta’ studji u informazzjoni dwar l-utilità u l-impatti tal-mina. Filfatt, għadu ma ġiex stabbilit jekk il-mina hux se tiffaċilita l-mobilità bejn iż-żewġ gżejjer. Id-deċiżjoni dwar jekk il-mina hijiex l-aħjar soluzzjoni għall-isfidi ta’ mobilità għandha tittieħed biss wara li jitwettqu studji indipendenti, serji u olistiċi. Barra minn hekk, il-pubbliku għandu d-dritt jipparteċipa f’konsultazzjoni siewja, u jiġi pprovdut b’informazzjoni dwar dan is-suġġett sabiex jiżviluppa opinjoni infurmata.
L-impressjoni li ngħatat mill-Project Description Statement ippubblikat mill-Awtorità għall-Ambjent u r-Riżorsi (ERA) hija li l-mina se tipprovdi konnessjoni bla xkiel bejn Malta u Għawdex. Iżda, fil-prattika, dan mhux neċessarjament se jkun il-każ. Dak li qed jiġi propost huwa mina relattivament dejqa b’korsija waħda f’kull direzzjoni. Meta nikkunsidraw li mad-9,000 karozza għandhom jgħaddu minn ġo din il-mina ta’ kuljum, flimkien mal-fatt li l-mina nnifisha jista’ jkollha limitazzjonijiet fil-kapaċità minħabba kwistjonjiet ta’ sikurezza, tibqa’ tippersisti l-possibilità ta’ kjus twal. L-istudji għandhom jiddeterminaw jekk tabilħaqq il-mina hux se tnaqqas il-ħinijiet tal-ivvjaġġar bejn Malta u Għawdex, meta jiġu kkunsidrati l-kapaċità tal-mina stess kif ukoll il-konġestjoni ikbar tul ir-rotot li jwasslu għaliha.
L-opzjoni tal-mina għandha tiġi mqabbla ma’ opzjonijiet oħrajn f’termini ta’ spejjeż, impatti u effikaċja. Pereżempju, għandu jiġi serjament ikkunsidrat servizz ta’ katamaran veloċi li jipprovdi vjaġġi frekwenti minn Għawdex għal partijiet differenti tal-gżira Maltija. Il-mina inevitabilment se twassal san-naħa ta’ fuq tal-gżira Maltija, u l-vjaġġaturi Għawdxin se jkollhom jivvjaġġaw għall-post tax-xogħol jew studju tagħhom bil-possibilità li jsibu iktar traffiku mblukkat tul it-triq. Is-servizz tal-katamaran veloċi jista’ jindirizza din is-sitwazzjoni b’mod li mina ma tistax. L-aħjar soluzzjoni għat-titjib tal-konnessjoni bejn iż-żewġ gżejjer tista’ tiġi determinata biss permezz ta’ studji li jikkunsidraw u jqabblu l-opzjonijiet kollha possibbli.
L-opzjoni tal-mina għandha tiġi vvalutata minn perspettiva ta’ sostenibbiltà finanzjarja. Filwaqt li l-ispejjeż eżatti tal-mina għadhom ma ġewx determinati, huwa stmat li l-ispejjeż t tal-kostruzzjoni jistgħu jilħqu t-300 miljun ewro. Barra minn hekk, mina teħtieġ miljuni ta’ ewro fis-sena biex tiġi mmonitorjata, mantnuta u mħaddma. Id-dikjarazzjonijiet li l-mina se tiġi ffinanzjata kollha kemm hi mis-settur privat mhumiex realistiċi. Jekk il-pedaġġ għandu jibqa’ affordabbli, sussidji kostanti u sinifikanti mill-Gvern se jkunu inevitabbli. L-istudji għandhom jiddeterminaw il-livell ta’ dawn is-sussidji u s-sostenibbiltà tagħhom fuq żmien twil.
Huwa essenzjali li l-istudji dwar il-mina ma jkunux limitati għall-kostruzzjoni u t-tħaddim tal-mina nnifisha, iżda tittieħed kunsiderazzjoni wiesgħa tal-impatti tagħha. Pereżempju, l-istudju għandhom jistabbilixxu x’se jkunu l-konsegwenzi fuq is-soċjetà, l-ambjent, l-ekonomija u l-infrastruttura Għawdxija minħabba ż-żieda fil-karozzi u fl-ispekulazzjoni.
Huwa mistenni li l-mina se jkollha impatt mifrux fuq l-ambjent. Qabel ma tintagħżel l-opzjoni tal-mina, għandha tiġi vvalutata l-firxa sħiħa tal-impatt ambjentali fuq Malta u Għawdex, u jiġu kkunsidrati fatti bħal:
  • it-teħid ta’ art agrikola u naturali sostanzjali għaż-żewġ daħliet u għan-netwerks tat-toroq anċillarji
  • il-ġenerazzjoni ta’ volum mingħajr preċedenti ta’ skart, stmat li jkun ta’ iktar minn miljun metru kubu
  • l-effetti diretti u indiretti fuq tal-inqas erba’ siti ta’ Natura 2000, li jinkludu r-Riżervi Naturali tas-Simar u tal-Għadira
  • l-effetti potenzjalment devastanti fuq l-akwifer tal-Miżieb/l-Imbordin, li ta l-ilma lill-wied tal-Pwales għal eluf ta’ snin
  • il-qerda u/jew il-kontaminazzjoni tal-akwifer tal-Pwales, li bħalissa jrendi madwar sitt miljun metru kubu ta’ ilma fis-sena
  • iż-żieda fit-traffiku u t-tniġġis u l-impatt tagħhom fuq l-ambjent naturali u l-kwalità tal-ħajja, kemm f’Malta kif ukoll f’Għawdex
  • l-istorbju u l-vibrazzjonijiet li jirriżultaw mix-xogħol ta’ tħaffir u l-impatt tagħhom fuq qiegħ il-baħar u l-abitati naturali tal-madwar
  • jekk hux se jkun hemm infrastruttura għaċ-ciklisti li, jekk se tkun nieqsa, se ġġiegħel lin-nies jivvjaġġaw bil-karozza
Il-proposta attwali, li tinvolvi t-tqegħid tad-daħla tal-mina qrib ir-raħal pittoresk tal-Imbordin, qajmet ukoll tħassib arkeoloġiku. Iż-żona tal-Imbordin fiha għerien naturali u parzjalment imkabbra li probabbilment iwasslu għall-perjodu ta’ żmien qabel il-wasla tal-Kavallieri, u ż-żona hija magħrufa wkoll għall-“giardini” ta’ żmien il-Kavallieri. Kemm l-għerien kif ukoll il-“giardini” aktarx jiġu mhedda mit-tħaffir tad-daħla tal-mina u tal-infrastruttura tagħha. L-għerien intużaw għal sekli sħaħ u jinsabu f’kundizzjoni tajba. Barra minn hekk, għadha għaddejja l-identifikazzjoni tas-sejbiet arkeoloġiċi fiż-żona.
Meħud kont tal-iskala kbira tal-impatti li se tħalli l-mina, qed nitolbu Strategic Environment Assessment (SEA), li għandu jitwettaq qabel ma jitkomplew il-pjanijiet. L-SEA huwa obbligu legali għal kwalunkwe pjan jew programm ippreparat mill-gvern li jista’ jkollu effett sinifikanti fuq l-ambjent. Dan għandu l-għan li jipprevedi l-impatti ambjentali, jivvaluta alternattivi raġjonevoli u miżuri ta’ mitigazzjoni, jinvolvi ruħu f’konsultazzjonijiet fuq skala wiesgħa u jinfluwenza l-pjanijiet billi jindirizza kwistjonijiet ambjentali fi stadju bikri.
Huwa biss wara li jiġu konklużi u ppubblikati l-istudji neċessarji li tista’ tibda diskussjoni sinifikanti dwar il-mina bejn Malta u Għawdex. Dawn l-istudji għandhom jagħtu tweġibiet għal bosta mistoqsijiet importanti, fosthom:
  • Meħud kont tal-limitazzjonijiet tal-kapaċità u ż-żieda fit-traffiku, il-mina fil-verità ser tnaqqas il-ħinijiet tal-ivvjaġġar bejn iż-żewġ gżejjer?
  • Kif tikkumpara l-opzjoni tal-mina mal-opzjonijiet l-oħrajn, bħal servizz ta’ katamaran veloċi, f’termini ta’ effikaċja, spejjeż u impatti?
  • L-ispejjeż fuq terminu qasir u fit-tul tal-mina huma finanzjarjament sostenibbli?
  • Il-mina kif se taffettwa s-soċjetà, l-ekonomija, l-ambjent u l-infrastruttura ta’ Għawdex?
  • X’inhi l-firxa sħiħa tal-impatt tal-mina fuq l-ambjent?
F’dan l-istadju, ma għandna xejn li juri li l-mina ser tindirizza b’mod effettiv l-isfidi tal-mobilità, u li l-impatti soċjali, ekonomiċi u ambjentali tagħha se jkunu sostenibbli.
Nittamaw li nipparteċipaw b’mod attiv f’diskussjoni infurmata dwar dan is-suġġett.
It-13-il għaqda li qegħdin jippartecipaw f’din il-Konferenza Stampa huma:
Ramblers Association, Din l-Art Ħelwa, Archaeological Society Malta, Moviment Graffitti, BirdLife Malta, Kamra tal-Periti, Nature Trust Malta, Flimkien għal Ambjent Aħjar, Friends of the Earth Malta, Għaqda Siġar Maltin, Isles of the Left, Bicycle Advocacy Group u Żminijietna
Latest from our blog
Today, on the sixth anniversary of Lassana Cisse’s murder, we gathered to honour his life through a football match—celebrating his...
Activists from several Maltese organisations are staging a solidarity action during the Malta–Israel rugby match at the Paola stadium. Last...
Today, we gathered together with Żurrieq farmers, residents, and other groups in front of the Lands Authority, where we held...
